Version: 8.1
system.gui.isTouchscreenModeEnabled
Checks whether or not the running Client's Touch Screen mode is currently enabled.
system.gui.isTouchscreenModeEnabled()
Nothing
Boolean - True if the Client currently has Touch Screen mode activated.
Vision Client
Example #1
# This example is used in the Client Startup script to check if this Client is being run on a touch screen computer (judged by an IP address) and set Touch Screen mode.
ipAddress = system.net.getIpAddress()
query = "SELECT COUNT(*) FROM touchscreen_computer_ips WHERE ip_address = '%s' "
isTouchscreen = system.db.runScalarQuery(query %(ipAddress))
if isTouchscreen and not system.gui.isTouchscreenModeEnabled():
system.gui.setTouchscreenModeEnabled(1)
