system.gui.createPopupMenu
Descriptionβ
Creates a new popup menu, which can then be shown over a component on a mouse event. To use this function, first create a Python sequence whose entries are strings, and another sequence whose entries are function objects. The strings will be the items that are displayed in your popup menu, and when an item is clicked, its corresponding function will be run. Your functions must accept an event object as an argument. See also: Functions.
The function returns a JPopupMenu. This object has a show(event) function that allows your code to determine when the popup menu should show itself. See the examples for more information.
A popup menu must be created on either the mousePressed or mouseReleased event handlers. This function is not appropriate for invoking on the property change event.
Also, the mouse motions that invoke the popup menu are dependent on the operating system and may behave differently depending on which button you press on the mouse. Because of the different popup-trigger settings on different operating systems, the example code may behave differently on Linux or iOS. The way around this is to do the same code in both the mousePressed and mouseReleased events. In order to avoid code duplication, consider placing the code in a custom method.
Syntaxβ
system.gui.createPopupMenu(itemNames, itemFunctions)
Parametersβ
| List[String] | itemNames | A list of names to create popup menu items with. |
| List[String] | itemFunctions | A list of functions to match up with the names. Passing in a None object will cause a separator line to appear in the popup menu, and the corresponding string will not be displayed (note that a corresponding string must be supplied, since the number of elements in the itemFunctions parameter must always match the number of elements in the itemNames parameter). |
Returnsβ
JPopupMenu - The javax.swing.JPopupMenu that was created.
Scopeβ
Vision Client
Code Examplesβ
# This first example demonstrates the fundamentals of making a popup menu. Put the following script in the mouseReleased event of a component.
# This will only work on Windows - continue on for cross-platform instructions.
# Right click on the component to see the resulting pop-up menu that is created with this code.
def sayHello(event):
system.gui.messageBox("Hello World")
menu = system.gui.createPopupMenu(["Click Me"], [sayHello])
menu.show(event)
# Similar to the first example, we'll add an additional option, as well as a separator between the two options.
def sayGoodbye(event):
system.gui.messageBox("See you later")
menu = system.gui.createPopupMenu(["Say Hi", "Separator", "Say Goodbye"], [sayHello, None, sayGoodbye])
menu.show(event)
# The following code demonstrates how to edit a component's custom property after you right clicked the component.
# This code makes use of functions in order to edit the components custom properties.
# The following code should be located in the mouse released event handler.
# Also, there must be custom properties present on the component in order to handle these functions.
# For example, there must be a custom property called 'DatabaseProvider' that takes a string.
if event.button != event.BUTTON1:
def editDatabaseProvider(event):
result = system.gui.inputBox("Database Provider",event.source.parent.DatabaseProvider)
event.source.parent.DatabaseProvider = result
def editTable(event):
result = system.gui.inputBox("Table Name",event.source.parent.Table)
event.source.parent.Table = result
def editColumn(event):
result = system.gui.inputBox("Column Name",event.source.parent.Column)
event.source.parent.Column = result
def editKeyColumn(event):
result = system.gui.inputBox("Key Column Name",event.source.parent.KeyColumn)
event.source.parent.KeyColumn = result
names = ["Edit DB Provider", "Edit Table Name", "Edit Column Name", "Edit Key Column"]
functions = [editDatabaseProvider, editTable, editColumn, editKeyColumn]
menu = system.gui.createPopupMenu(names, functions)
menu.show(event)
# This example shows a nested popup menu, with menus within menus. All menu items call sayHello().
subMenu = [["Click Me 2", "Click Me 3"], [sayHello, sayHello]]
menu = system.gui.createPopupMenu(["Click Me", "SubMenu"], [sayHello, subMenu])
menu.show(event)
