system.gui.closeDesktop
Descriptionβ
Allows you to close any of the open desktops associated with the current client. See the Multi-Monitor Clients page for more details about using multiple monitors.
Syntaxβ
system.gui.closeDesktop(handle)
Parametersβ
| String | handle | The handle for the desktop to close. The screen index cast as a string may be used instead of the handle. If omitted, this will default to the primary desktop. Alternatively, the handle "primary" can be used to refer to the primary desktop. |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
Example #1
# The following example will close this desktop
system.gui.closeDesktop()
Example #2
# The following example will close desktop 2
# The handle must be a string
system.gui.closeDesktop("2")
Example #3
# The following example will close the desktop named "Left Monitor"
system.gui.closeDesktop("Left Monitor")
