system.vision.getScreens
Backwards Compatibility
This function replaces system.gui.getScreens. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Get a list of all the monitors on the computer this client is open on. Use with system.vision.setScreenIndex() to move the client.
Syntaxβ
system.vision.getScreens()
Parametersβ
Nothing
Returnsβ
List[Tuple[String, Integer, Integer]] - A sequence of tuples of the form (index, width, height) for each screen device (monitor) available.
Scopeβ
Vision Client
Code Examplesβ
Example #1 - Getting Screen Information
# This example fetches monitor data and pushes it to a table in the same container.
screens = system.vision.getScreens()
pyData = []
for screen in screens:
pyData.append([screen[0], screen[1], screen[2]])
# Push data to 'Table'.
event.source.parent.getComponent('Table').data = system.dataset.toDataset(["screen","width","height"], pyData)
