system.vision.desktop
Backwards Compatibility
This function replaces both system.gui.desktop and system.nav.desktop. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Allows for invoking system.vision functions on a specific desktop.
See the Multi-Monitor Clients page for more details.
Syntaxβ
system.vision.desktop(handle)
Parametersβ
| String | handle | The handle for the desktop to use. The screen index cast as a string may be used instead of the handle. If omitted, this will default to the primary desktop. Alternatively, the handle "primary" can be used to refer to the primary desktop. |
Returnsβ
VisionUtilities - A copy of system.vision (VisionUtilities) that will be relative to the desktop named by the given handle.
Scopeβ
Vision Client
Code Examplesβ
Example #1
# Attempts to swap to a window at path "Main Windows/Main Window" on a specific Desktop.
# This example assumes a desktop with the handle "2nd Desktop" is already open.
system.vision.desktop("2nd Desktop").swapTo("Main Windows/Main Window")
Example #2 - Opening Message Box in a Different Desktop
# The following example makes a message box appear on the primary desktop,
# regardless of where the script originates.
# system.vision.desktop() function requires a handle be passed to it for this example
# to work properly.
system.vision.desktop().showMessage("This will appear on the Primary Desktop")
Example #3 - Showing Open Windows in a Specific Desktop
# Retrieves a list of open windows in a specific Desktop.
# This example assumes a desktop with the handle "2nd Desktop" exists.
name = "2nd Desktop"
# Returns a tuple of open windows in the Desktop named "2nd Desktop".
windows = system.vision.desktop(name).getOpenedWindows()
# Converts the tuple to a string, and shows the items in a message box.
system.vision.showMessage(str(windows))
