system.vision.showWarning
Backwards Compatibility
This function replaces system.gui.warningBox. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Displays a message to the user in a warning style popup dialog.
Syntaxβ
system.vision.showWarning(message, [title])
Parametersβ
| String | message | The message to display in the warning. Will accept HTML formatting if the message parameter is encapsulated in an <html> tag. |
| String | title | The title for the warning. [optional] |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This code shows a yellow popup box similar to the system.gui.messageBox function.
# Start the motor, or, warn the user if in wrong mode.
runMode = event.source.parent.getPropertyValue('RunMode')
# Cannot start the motor in mode #1
if runMode == 1:
system.vision.showWarning("Cannot start the motor, current mode is <B>VIEW MODE</B>")
else:
system.db.runUpdateQuery("UPDATE MotorControl SET MotorRun=1")
