Version: 8.3
system.vision.getAvailableLocales
Backwards Compatibility
This function replaces system.util.getAvailableLocales. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Returns a collection of the locales defined on the system, as strings. Note that these are only the locales that are defined in the translation system.
system.vision.getAvailableLocales()
Nothing
List - A list of strings, each representing a locale defined in the translation system.
Locale Format
The returned strings use the legacy underscore form (such as en_US) rather than a BCP-47 language tag (such as en-US). If you need to pass one of these values somewhere that expects a language tag, replace the underscore with a hyphen. See Locale Formats and Language Tags.
Vision Client
Example #1
# This example simply lists the available locales for the system.
