system.vision.showConfirm
Backwards Compatibility
This function replaces system.gui.confirm. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Displays a confirmation dialog box to the user with Yes and No options, and a custom message.
note
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
system.vision.showConfirm(message, [title], [allowCancel])
Parametersβ
| String | message | The message to show in the confirmation dialog. |
| String | title | The title for the confirmation dialog. [optional] |
| Boolean | allowCancel | Show a cancel button in the dialog. [optional] |
Returnsβ
Boolean - True if the user selected Yes; false if the user selected No. None if the user selected Cancel.
Scopeβ
Vision Client
Code Examplesβ
Example #1
# By using the confirm function in an if statement, we can let the user confirm an action.
# In this case, we shut down the plant if the user confirms it; otherwise, we don't do anything.
if system.vision.showConfirm("Are you sure you want to shutdown the plant?", "Really Shutdown?"):
system.db.runPrepUpdate(
"UPDATE ControlTable SET Shutdown = ?",
[1]
