Version: 8.3
system.vision.centerWindow
Backwards Compatibility
This function replaces system.nav.centerWindow. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Given a window path, or a reference to a window itself, it will center the window. The window should be floating an non-maximized. If the window can't be found, this function will do nothing.
note
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntax #1 (String param)​
system.vision.centerWindow(windowPath)
StringwindowPathThe path of the window to center.
Nothing
Vision Client
Syntax #2 (FPMIWindow param)​
system.vision.centerWindow(window)
FPMIWindowwindowA reference to the window to center.
Nothing
Vision Client
Example #1
# This example centers the window named 'Overview'.
system.vision.centerWindow('Overview')
