system.vision.showNumericKeypad
This function replaces system.gui.showNumericKeypad. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Displays a modal on-screen numeric keypad, allowing for arbitrary numeric entry using the mouse, or a finger on a touch screen monitor. Returns the number that the user entered.
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
system.vision.showNumericKeypad(initialValue, [fontSize], [usePasswordMode])
Parametersβ
| Number | initialValue | The value to start the on-screen keypad with. |
| Integer | fontSize | The font size to display in the keypad. [optional] |
| Boolean | usePasswordMode | If True, display a * for each digit. [optional] |
Returnsβ
Number - The value that was entered in the keypad.
Scopeβ
Vision Client
Code Examplesβ
# This function is a holdover for backwards compatibility. Input components now know when the Client is in Touch Screen mode and respond accordingly.
# This script would go in the MouseClicked or MousePressed action of a Text field or Numeric Text field.
# For Integer Numeric Text field:
if system.vision.isTouchscreenMode():
event.source.intValue = system.vision.showNumericKeypad(event.source.intValue)
# For Double Numeric Text field:
event.source.doubleValue = system.vision.showNumericKeypad(event.source.doubleValue)
# For Text field:
# Notice the str() and int() functions used to convert the text to a number and
# vice versa.
# str() and int() are built-in Jython functions
event.source.text = str(system.vision.showNumericKeypad(int(event.source.text)))
