system.vision.exportExcel
Backwards Compatibility
This function replaces system.dataset.exportExcel. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Exports the contents of a dataset as an Excel spreadsheet, prompting the user to save the file to disk. To write silently to a file, you cannot use the vision.export* functions. Instead, use the system.dataset.toExcel function.
Syntaxβ
system.vision.exportExcel(filename, showHeaders, dataset, [nullsEmpty])
Parametersβ
| String | filename | A suggested filename to save as. |
| Boolean | showHeaders | If true, the spreadsheet will include a header row. |
| Dataset \ List[Dataset] | dataset | Either a single dataset, or a list of datasets. When passing a list, each element represents a single sheet in the resulting workbook. |
| Boolean | nullsEmpty | If True, the spreadsheet will leave cells with NULL values empty, instead of allowing Excel to provide a default value like 0. Defaults to False. [optional] |
Returnsβ
String - The path to the saved file, or None if the action was canceled by the user.
Scopeβ
Vision Client
Code Examplesβ
Code Snippet
# This snippet prompts the user to save the data currently displayed in a Table component
# to an Excel-compatible spreadsheet file. It opens the file after a successful save.
table = event.source.parent.getComponent("Table")
filePath = system.vision.exportExcel("data.xlsx", 1, table.data)
if filePath != None:
system.net.openURL("file://"+filePath)
