system.vision.showError
Backwards Compatibility
This function replaces system.gui.errorBox. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Displays an error-style message box to the user.
note
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
system.vision.showError(message, [title])
Parametersβ
| String | message | The message to display in an error box. Will accept HTML formatting. |
| String | title | The title for the error box. [optional] |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
Example #1 - Using Error Box
# Turn on compressor #12, but only if the user has the right credentials.
if 'Supervisor' in system.vision.getRoles():
updateQuery = "UPDATE CompressorControl SET running=1 WHERE compNum = 12"
system.db.runUpdateQuery(updateQuery)
else:
errorMessage = "Unable to turn on Compressor 12."
errorMessage += " You don't have proper security privileges."
system.vision.showError(errorMessage)
