system.vision.setTouchscreenMode
Backwards Compatibility
This function replaces system.gui.setTouchscreenModeEnabled. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Alters a running Client's Touch Screen mode on the fly.
Syntaxβ
system.vision.setTouchscreenMode(enabled)
Parametersβ
| Boolean | enabled | The new value for Touch Screen mode being enabled. |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Exampleβ
Example #1 - Enabling Touch Screen Mode
# This example could be used on an input heavy window's internalFrameActivated event
# to remove Touch Screen mode.
if system.vision.isTouchscreenMode():
system.vision.setTouchscreenMode(False)
