system.vision.getParentWindow
Backwards Compatibility
This function replaces system.gui.getParentWindow. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Finds the parent (enclosing) window for the component that fired an event and returns a reference to it.
note
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
system.vision.getParentWindow(event)
Parametersβ
| EventObject | event | A component event object. |
Returnsβ
FPMIWindow - The window that contains the component that fired the event.
Scopeβ
Vision Client
Code Examplesβ
Example #1 - Getting Window and Changing Its Title
# Use this in an event script to change the window's title.
window = system.vision.getParentWindow(event)
window.title='This is a new title'
