system.vision.showTouchscreenKeyboard
This function replaces system.gui.showTouchscreenKeyboard. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Displays a modal on-screen keyboard, allowing for arbitrary text entry using the mouse, or a finger on a touchscreen monitor. Returns the text that the user entered.
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
system.vision.showTouchscreenKeyboard(initialText, [fontSize], [passwordMode])
Parametersβ
| String | initialText | The text to start the on-screen keyboard with. |
| Integer | fontSize | The font size to display in the keyboard. [optional] |
| Boolean | passwordMode | A True value will activate password mode, where the text entered is not echoed back in cleartext. [optional] |
Returnsβ
String - The text that was entered in the on-screen keyboard.
Scopeβ
Vision Client
Code Examplesβ
# This function is a holdover for backwards compatibility. Input components now know when the client
# is in Touch Screen mode and respond accordingly.
# This would go in the MouseClicked or MousePressed action of a Text Field or similar component.
if system.vision.isTouchscreenMode():
event.source.text = system.vision.showTouchscreenKeyboard(event.source.text)
