system.vision.swapWindow
This function replaces system.nav.swapWindow. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Performs a window swap. This means that one window is closed, and another is opened and takes its place - assuming its size, floating state, and maximization state. This gives a seamless transition - one window seems to simply turn into another.
This function works like system.vision.swapTo, except that you can specify the source and destination for the swap.
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntax #1 (String param)β
system.vision.swapWindow(swapFromPath, swapToPath, [params])
Parametersβ
| String | swapFromPath | The path of the window to swap from. Must be a currently open window, otherwise this will act like an openWindow. |
| String | swapToPath | The name of the window to swap to. |
| Dictionary[String, Any] | params | A dictionary of parameters to pass into the window. The keys in the dictionary must match dynamic property names on the target window's root container. The values for each key will be used to set those properties. [optional] |
Returnsβ
Window - A reference to the swapped-to window.
Scopeβ
Vision Client
Syntax #2 (EventObject param)β
system.vision.swapWindow(event, swapToPath, [params])
Parametersβ
| EventObject | event | A component event whose enclosing window will be used as the "swap-from" window. |
Returnsβ
Window - A reference to window that was navigated to. Refer to the list of window objects.
Scopeβ
Vision Client
Code Examplesβ
# This code would go in a button's ActionPerformed event to swap out of the
# window containing the button and into a window named MyWindow.
system.vision.swapWindow(event, "MyWindow")
# This code would swap from window named WindowA to a window named WindowB.
system.vision.swapWindow("WindowA", "WindowB")
# It also looks at the two calendar popup controls and passes the two selected
# dates to WindowB. WindowB's Root Container must have dynamic properties named
# "startDate" and "endDate".
date1 = event.source.parent.getComponent("Start Date").date
date2 = event.source.parent.getComponent("End Date").date
system.vision.swapWindow("WindowA", "WindowB", {"startDate":date1, "endDate":date2})
