system.vision.printToImage
This function replaces system.print.printToImage. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
This function prints the given component (such as a graph, container, entire window, etc) to an image file, and saves the file where ever the operating system deems appropriate. A filename and path may be provided to determine the name and location of the saved file.
While not required, it is highly recommended to pass in a filename and path. The script may fail if the function attempts to save to a directory that the client does not have access rights to.
Syntaxβ
system.vision.printToImage(component [, filename])
Parametersβ
| Component | component | The component to render. |
| String | filename | A filename to save the image as. [optional] |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
# This code would go on a button and save an image of the container that it is in.
system.vision.printToImage(event.source.parent, "C:\\temp\\Screen.jpg")
# Again, this example would save an image of the container, but prompts the user for a
# location and filename with system.vision.saveFile()
# Ask the user for a location. Uses a default filename of "image.png"
path = system.vision.saveFile("image.png")
# If the path is not None...
if path != None:
#Save the file
system.vision.printToImage(event.source.parent, path)
