system.vision.goHome
This function replaces system.nav.goHome. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
When using the typical navigation strategy, this function will navigate to the "home" window. This is automatically detected as the first main-screen window shown in a project. If you are using this system function with system.vision.openWindow(), your home window should be closed before navigating to it, or system.vision.goHome() may not work.
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
Parametersβ
Nothing
Returnsβ
Window - A reference to window that was navigated to. Refer to the list of window objects.
Scopeβ
Vision Client
Code Examplesβ
# This code would go in a button to move to the Home screen.
