Report Component - Polygon Shape
Component Palette Icon:
The Polygon shape component creates custom polygon shapes by drawing and connecting lines, and can be used anywhere on a report. Select the Polygon shape on the Report Component Palette to make it active, click once to start a line and click to anywhere else to add additional corners. Click on the starting location to form a polygon shape. Once the polygon component is created, you can use the handles to change its size. Double click on any of the individual lines to change the size and shape of the selected line. You can also change its stroke style, color, dash pattern, and much more by using its properties.
Properties​
PropertyDescriptionCategory
FillIf true, the shape will fill its space with color.Stroke and Fill
Fill ColorIf Fill is selected, the color that will fill the shape.Stroke and Fill
OpacityHow opaque the fill color is, between 0 and 1.Stroke and Fill
Stroke StyleWhat style of stroke or border to use: Hidden, Shape Outline, Border, or Double. To learn more about stroke styles, refer to Stroke and Fill Properties.Stroke and Fill
StrokeDetails for the chosen stroke. Each Stroke has its own properties depending on the Stroke Style chosen.Stroke and Fill
RollNumber of degrees this shape is rotated clockwise.Basic Properties
Scale XAmount to scale the width of this shape. 1 is scale to 100%.Basic Properties
Scale YAmount to scale the height of this shape. 1 is scale to 100%.Basic Properties
VisibleIf true, the shape will be visible.Basic Properties
WidthWidth of this shape in pixels.Basic Properties
HeightHeight of this shape in pixels.Basic Properties
XHorizontal distance in pixels between the left edge of this shape and the left edge of the page.Basic Properties
YVertical distance in pixels between the upper edge of this shape and the top edge of the page.Basic Properties
Example​
Draw a triangle by clicking in 3 places on your screen, then once more at your start location.
PropertyValue
Fill ColorGreen
Stroke StyleShape Outline
Stroke ColorRed
Stroke Width3 pixels
