Report Component - Star Shape
Component Palette Icon:
The Star shape component creates a star and can be used anywhere on a report. Select the Star shape on the Report Component Palette to make it active, and draw a star anywhere in your Report Designer. Once the star is created you can use the handles to resize it. You can change the number of star points, bloat, color, stroke, and much more using its properties.
Properties​
PropertyDescriptionCategory
BloatHow wide each arm of the star is. 0 will give lines for each arm, 1 makes the star a polygon with twice as many sides as the points property.Star Shape
PointsNumber of points in the star shape.Star Shape
Star TypeSwitches the star shape from a Star to a Polygon.Star Shape
FillIf true, the shape will fill its space with color.Stroke and Fill
Fill ColorIf Fill is selected, the color that will fill the shape.Stroke and Fill
OpacityHow opaque the fill color is, between 0 and 1.Stroke and Fill
Stroke StyleWhat style of stroke or border to use: Hidden, Shape Outline, Border, or Double. To learn more about stroke styles, refer to Stroke and Fill Properties.Stroke and Fill
StrokeDetails for the chosen stroke. Each Stroke has its own properties depending on the Stroke Style chosen.Stroke and Fill
RollNumber of degrees this shape is rotated clockwise.Basic Properties
Scale XAmount to scale the width of this shape. 1 is scale to 100%.Basic Properties
Scale YAmount to scale the height of this shape. 1 is scale to 100%.Basic Properties
VisibleIf true, the shape will be visible.Basic Properties
WidthWidth of this shape in pixels.Basic Properties
HeightHeight of this shape in pixels.Basic Properties
XHorizontal distance in pixels between the left edge of this shape to the left edge of the page.Basic Properties
YVertical distance in pixels between the upper edge of this shape to the top edge of the page.Basic Properties
Example​
PropertyValue
Points8
Fill ColorPink
Stroke ColorBlue
Roll20
