File Explorer
Component Palette Icon:
Inductive University
File Explorer
Watch the video
The File Explorer component displays a filesystem tree to the user. It can be rooted at any folder, even network folders. It can also filter the types of files that are displayed by their file extension (i.e., "pdf"). The path to the file that the user selects in the tree is exposed in the bindable property Selected Path.
The File Explorer component is typically used in conjunction with the PDF Viewer component in order to create a PDF viewing window. This is very useful for viewing manuals, documents, or reports from within your project. To use this component to drive a PDF Viewer component, refer to the section on File Explorer and PDF Viewer.
Properties​
NameDescriptionProperty TypeScriptingCategory
Background ColorThe background color of the component.Color.backgroundAppearance
BorderThe border surrounding this component. NOTE that the border is unaffected by rotation.Border.borderCommon
CursorThe mouse cursor to use when hovering over this component.int.cursorCodeCommon
EnabledIf disabled, the component can't be used.boolean.componentEnabledCommon
File extension filterSemi-colon seperated list of extensions to filter out files, such as pdf or txt. Example "pdf;html;txt" shows pdf, html, and text documents.String.fileFilterBehavior
FontFont of text on this component.Font.fontAppearance
Foreground ColorThe foreground color of the component.Color.foregroundAppearance
Mouseover TextThe text that is displayed in the tooltip which pops up on mouseover of this component.String.toolTipTextCommon
NameThe name of this component.String.nameCommon
Root DirectoryA directory to act as the root of the file explorer.String.rootDirBehavior
Selected PathThe selected file or folder's path.String.selectedPathData
VisibleIf disabled, the component will be hidden.boolean.visibleCommon
Scripting​
Scripting Functions​
This component does not have scripting functions associated with it.
Extension Functions​
Event Handlers​
Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the Component Events page.
Customizers​
The File Explorer component does not have a customizer.
Examples​
Refer to the example on the Vision Reporting Components page.
