Report Component - Line Shape
Component Palette Icon:
The Line shape component can be used to display a straight line any where in a report. It can run north-south, east-west, or diagonally. Select the Line shape on the Report Component Palette to make it active, and click and drag to draw a Line any where in your Report Designer. Hold shift while dragging to force the angle of the line to a 45 or 90 degree angle. You can change the stroke style, color, width, pattern, and more.
Properties​
PropertyDescriptionCategory
FillIf true, the shape will fill its space with color.Stroke and Fill
Fill ColorIf true is selected, the color that will fill the shape.Stroke and Fill
OpacityHow opaque the fill color is, between 0 and 1.Stroke and Fill
Stroke StyleWhat style of stroke or border to use: Hidden, Shape Outline, Border, or Double. To learn more about stroke styles, refer to Stroke and Fill Properties.Stroke and Fill
StrokeDetails for the chosen stroke. Each Stroke has its own properties depending on the Stroke Style chosen.Stroke and Fill
RollNumber of degrees this shape is rotated clockwise.Basic Properties
Scale XAmount to scale the width of this shape. 1 is scale to 100%.Basic Properties
Scale YAmount to scale the height of this shape. 1 is scale to 100%.Basic Properties
VisibleIf true, the shape will be visible.Basic Properties
XHorizontal distance in pixels between the left edge of this shape and the left edge of the page.Basic Properties
YVertical distance in pixels between the upper edge of this shape and the top edge of the page.Basic Properties
Stroke ColorColor of the line.Line Properties
Stroke WidthWidth of the stroke in pixels.Line Properties
Example - Two Lines​
PropertyValue
Stroke StyleBorder
Stroke ColorAmber
Border BottomTrue
Border TopTrue
Stroke Width5 pixels
