system.util.modifyTranslation
This function allows you to add or modify a global translation.
Permission Type: Translation Management
system.util.modifyTranslation(term, translation [, locale])
StringtermThe key term to translate.
StringtranslationThe translated value to store.
StringlocaleIf specified, the locale code (such as "es") identifying the language of the translation. Otherwise, the currently set language is used.[optional]
Nothing
Client
Example #1
# This code adds or updates a translation into French
# for the world Hello. Note the u in front "Allô!", which
# is needed for Python strings outside of the 7-bit ASCII
# range.
system.util.modifyTranslation("Hello", u"Allô!", "fr")
