system.util.modifyTranslation
Description
This function allows you to add or modify a global translation.
Client Permission Restrictions
Permission Type: Translation Management
Syntax
system.util.modifyTranslation(term, translation, [locale])
Parameters
| String | term | The key term to translate. |
| String | translation | The translated value to store. |
| String | locale | If specified, the locale code (such as "es") identifying the language of the translation. Otherwise, the currently set language is used.[optional] |
Returns
Nothing
Scope
Code Examples
Example #1
# This code adds or updates a translation into French
# for the world Hello. Note the u in front "Allô!", which
# is needed for Python strings outside of the 7-bit ASCII
# range.
system.util.modifyTranslation("Hello", u"Allô!", "fr")
