system.util.queryAuditLog
Descriptionβ
Queries an audit profile for audit history. Returns the results as a dataset.
A description of the returned dataset can be found on the Ignition Database Table Reference page.
Syntax - Gateway Scopeβ
system.util.queryAuditLog(auditProfileName, [startDate], [endDate], [actorFilter], [actionFilter], [targetFilter], [valueFilter], [systemFilter], [contextFilter])
Parametersβ
| String | auditProfileName | The name of the audit profile to pull the history from. |
| Date | startDate | The earliest audit event to return. If omitted, the current time - 8 hours will be used. [optional] |
| Date | endDate | The latest audit event to return. If omitted, the current time will be used. [optional] |
| String | actorFilter | A filter string used to restrict the results by actor. [optional] |
| String | actionFilter | A filter string used to restrict the results by action. [optional] |
| String | targetFilter | A filter string used to restrict the results by target. [optional] |
| String | valueFilter | A filter string used to restrict the results by value. [optional] |
| String | systemFilter | A filter string used to restrict the results by system. [optional] |
| Integer | contextFilter | A bitmask used to restrict the results by context. 0x01 = Gateway, 0x02 = Designer, 0x04 = Client. [optional] |
Returnsβ
Dataset - A dataset with the audit events from the specified profile that match the filter arguments.
Scopeβ
Gateway
Syntax - Perspective Session and Vision Client Scopeβ
system.util.queryAuditLog([auditProfileName], [startDate], [endDate], [actorFilter], [actionFilter], [targetFilter], [valueFilter], [systemFilter], [contextFilter])
Parametersβ
| String | auditProfileName | The name of the audit profile to pull the history from. [optional] Note: The project must have an Audit Profile configured in Project Properties. Otherwise this parameter is mandatory. |
Returnsβ
Scopeβ
Perspective Session, Vision Client
Code Examplesβ
# This script queries an audit log, checks to see if a user john made any tag writes in the last 8 hours
# (since the startDate parameter is omitted), and writes the results to a table.
data = system.util.queryAuditLog(auditProfileName='AuditLog', actorFilter='john', actionFilter='tag write')
event.source.parent.getComponent("Table").data = data
