system.util.queryAuditLog
Queries an audit profile for audit history. Returns the results as a dataset.
system.util.queryAuditLog(auditProfileName, startDate, endDate, actorFilter, actionFilter, targetFilter, valueFilter, systemFilter, contextFilter)
StringauditProfileNameThe name of the audit profile to pull the history from.
DatestartDateThe earliest audit event to return. If omitted, the current time - 8 hours will be used.
DateendDateThe latest audit event to return. If omitted, the current time will be used.
StringactorFilterA filter string used to restrict the results by actor.
StringactionFilterA filter string used to restrict the results by action.
StringtargetFilterA filter string used to restrict the results by target.
StringvalueFilterA filter string used to restrict the results by value.
StringsystemFilterA filter string used to restrict the results by system.
IntegercontextFilterA bitmask used to restrict the results by context. 0x01 = Gateway, 0x02 = Designer, 0x04 = Client.
Dataset - A dataset with the audit events from the specified profile that match the filter arguments.
Client
Example #1
# This script queries an audit log, checks to see if a user john made any tag writes in the last 8 hours
# (since the startDate parameter is omitted), and writes the results to a table.
data = system.util.queryAuditLog(auditProfileName='AuditLog', actorFilter='john', actionFilter='tag write')
event.source.parent.getComponent("Table").data = data
