system.util.setLoggingLevel
Sets the logging level on the given logger. This can be a logger you create, or a logger already defined in the system.
system.util.setLoggingLevel(loggerName, loggerLevel)
StringloggerNameThe unique name of the logger to change the logging level on, for example "Tags.Client".
StringloggerLevelThe level you want to change to logger to: "trace", "debug", "info", "warn" or "error".
Nothing
All
Example #1
system.util.setLoggingLevel("Reporting", "debug") # This would set the logger called Reporting to the debug level.
