system.util.translate
This function allows you to retrieve the global translation of a term from the translation database using the current locale.
Syntax - term Parameter only​
system.util.translate(term)
StringtermThe term to look up.
String - The translated term.
Client
Syntax - term, locale, and strict Parameters​
system.util.translate(term, locale, strict)
  • Parameters
    • String term - The term to look up.
    • String locale
    • Boolean strict
  • Returns
    • String - The translated term.
  • Scope
    • Client
Example #1
# This script will take a term written into a Text Field component, translate it using the translation database, and then write it back to the same Text Field.
# it uses the current locale since none is specified.
text = event.source.parent.getComponent('Text Field').text
translation = system.util.translate(text)
event.source.parent.getComponent('Text Field').text = translation
