system.util.translate
Descriptionβ
This function allows you to retrieve the global translation of a term from the translation database using the current locale.
Syntaxβ
tip
system.util.translate(term, [locale], [strict])
Parametersβ
| String | term | The term to look up. |
| String | locale | Which locale to translate against. Useful when there are multiple locales defined for a single term. If omitted, the function attempts to use the current locale (as defined by the client, session, or Designer). [optional] |
| Boolean | strict | If false, the function will return the passed term (param 1) if it could not find a defined translation for the locale: meaning, if you pass a term that hasn't been configured, the function will just send the term back to you. If true, then the function will return a None when it fails to find a defined translation. Default is false. [optional] |
Returnsβ
String - The translated term.
Scopeβ
Code Examplesβ
Example #1
# This script will take a term written into a Text Field component, translate it using the translation database,
# and then write it back to the same Text Field.
# it uses the current locale since none is specified.
text = event.source.parent.getComponent('Text Field').text
translation = system.util.translate(text)
event.source.parent.getComponent('Text Field').text = translation
Example #2
# This code block demonstrates how to use the locale parameter.
# Use the currently detected locale.
system.util.translate("Hello")
# Translate to Italian.
system.util.translate("Hello", "it")
# Translate to a regional variant - Irish English in this case.
system.util.translate("Hello", "en-ie")
