system.util.setConnectionMode
Sets the connection mode for the client session. Normally a client runs in mode 3, which is read-write. You may wish to change this to mode 2, which is read-only, which will only allow reading and subscribing to tags, and running SELECT queries. Tag writes and INSERT/UPDATE/DELETE queries will not function. You can also set the connection mode to mode 1, which is disconnected, all tag and query features will not work.
system.util.setConnectionMode(mode)
| Integer | mode | The new connection mode. 1 = Disconnected, 2 = Read-only, 3 = Read/Write. |
Nothing
Vision Client
Example #1
# This example, which could go in a project's startup script, would check the current username
# and set the connection mode to read-only if it is the "guest" user.
username = system.security.getUsername()
if "guest" == username.lower():
# Set "guest" user to read-only mode
system.util.setConnectionMode(2)
else:
system.util.setConnectionMode(3)
