system.util.setLoggingLevel
Descriptionβ
Sets the logging level on the given logger. This can be a logger you create, or a logger already defined in the system.
Syntaxβ
system.util.setLoggingLevel(loggerName, loggerLevel)
Parametersβ
| String | loggerName | The unique name of the logger to change the logging level on, for example "Tags.Client". |
| String | loggerLevel | The level you want to change to logger to: "trace", "debug", "info", "warn" or "error". |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
Example #1
system.util.setLoggingLevel("Reporting", "debug") # This would set the logger called Reporting to the debug level.
