system.util.getSessionInfo
Descriptionβ
Returns a PyDataSet holding information about all of the open Designer sessions and Vision Clients. Optional regular-expression based filters can be provided to filter the username or the username and the project returned.
| Key | Description | Value |
| username | The username of the Session. | String |
| project | The project name associated with the Session. | String |
| address | The client's network address (IP address or hostname). | String |
| isDesigner | Whether the Session is a Designer Session (True or False) | Boolean |
| clientId | The unique ID of the client. | String |
| creationTime | The date when the Session was created. | Date |
This function will not return all sessions across a cluster - only the cluster node that is being communicated with by the client who makes the call.
tip
Syntaxβ
system.util.getSessionInfo([usernameFilter], [projectFilter])
Parametersβ
| String | usernameFilter | A regular-expression based filter string to restrict the list by username. [optional] |
| String | projectFilter | A regular-expression based filter string to restrict the list by project [optional] |
Returnsβ
PyDataSet - A dataset representing the Gateway's current sessions.
Scopeβ
Code Examplesβ
Example #1
# This code would get the entire table of sessions and put it in an adjacent table
table = event.source.parent.getComponent("Table")
sessions = system.util.getSessionInfo()
table.data = system.db.toDataSet(sessions)
Example #2
# This code would count the number of times a user named "billy" is logged in
sessions = system.util.getSessionInfo("billy")
system.gui.messageBox("Billy has %d sessions" % len(sessions))
Example #3
# This code would return session info on all users starting with the letters "bi"
sessions = system.util.getSessionInfo("bi.*")
Example #4
# This code uses a single character wildcard in the username
sessions = system.util.getSessionInfo("bi.ly")
Example #5
# This code would return session info on a user named "bill.smith"
sessions = system.util.getSessionInfo("bill\.smith")
