system.util.jsonEncode
Descriptionβ
Takes a Python object such as a list or dictionary and converts into a JSON string.
Syntaxβ
system.util.jsonEncode(pyObj, [indentFactor])
Parametersβ
| Any | pyObj | The Python object to encode into JSON such as a Python list or dictionary. |
| Integer | indentFactor | The number of spaces to add to each level of indentation for prettyprinting. [optional] |
Returnsβ
String - The encoded JSON string.
Scopeβ
JSON to Python Mappingβ
The table below lists possible Python types, and how they map to JSON objects.
| JSON Type | Mapped Python Type |
| Boolean (true/false) | Boolean (True/False) |
| String | String |
| Numeric | Number (Float, Integer) |
| null | None |
| Array | Sequence |
| Object | Dictionary |
New in 8.1.28 Float | BigDecimal (Java) |
Code Examplesβ
Example #1
# The following example builds a Python dictionary, and converts it to a JSON string
# Build the Python dictionary
employeeDict = {"employees":[{"firstName":"John", "lastName":"Doe"},{"firstName":"Anna", "lastName":"Smith"},{"firstName":"Peter", "lastName":"Jones"}]}
# Convert the dictionary and store the resulting JSON string in a variable.
jsonString = system.util.jsonEncode(employeeDict)
