system.util.exit
Descriptionβ
Exits the running client, as long as the shutdown intercept script doesn't cancel the shutdown event. Set force to true to not give the shutdown intercept script a chance to cancel the exit. Note that this will quit the Client completely. you can use system.security.logout() to return to the login screen.
Syntaxβ
system.util.exit([force])
Parametersβ
| Boolean | force | If true (1), the shutdown-intercept script will be skipped. Default is false (0). [optional] |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This code would exit the client after confirming with the user.
if system.gui.confirm("Are you sure you want to exit?"):
system.util.exit()
