system.util.exit
Exits the running client, as long as the shutdown intercept script doesn't cancel the shutdown event. Set force to true to not give the shutdown intercept script a chance to cancel the exit. Note that this will quit the Client completely. you can use system.security.logout() to return to the login screen.
system.util.exit([force])
booleanforceIf true (1), the shutdown-intercept script will be skipped. Default is false (0). [optional]
Nothing
Client
Example #1
# This code would exit the client after confirming with the user.
if system.gui.confirm("Are you sure you want to exit?"):
system.util.exit()
