system.util.getConnectTimeout
Returns the connect timeout in milliseconds for all client-to-gateway communication. This is the maximum amount of time that communication operations to the Gateway will be given to connect. The default is 10,000ms (10 seconds).
system.util.getConnectTimeout()
None
int - The current connect timeout, in milliseconds. Default is 10,000 (ten seconds)
Client
Example #1
# This code would print out the current connect timeout
print system.util.getConnectTimeout()
