--- title: "system.util.getConnectTimeout" description: "Returns the connect timeout in milliseconds for all client-to-gateway communication." --- # system.util.getConnectTimeout > Returns the connect timeout in milliseconds for all client-to-gateway communication. This function is used in **Python Scripting**. ## Description Returns the connect timeout in milliseconds for all client-to-gateway communication. This is the maximum amount of time that communication operations to the Gateway will be given to connect. The default is 10,000ms (10 seconds). ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.util.getConnectTimeout()` ### Parameters None ### Returns **int** - The current connect timeout, in milliseconds. Default is 10,000 (ten seconds) ### Scope Client ## Code Examples ```python title="Example #1" # This code would print out the current connect timeout print system.util.getConnectTimeout() ```
