system.util.jsonDecode
Takes a json String and converts it into a Python object such as a list or a dict. If the input is not valid json, a string is returned.
system.util.jsonDecode(jsonString)
StringjsonStringThe JSON string to decode into a Python object.
PyObject - The decoded Python object.
All
Example #1
# The following example reads in a JSON string, and converts the string to a Python object.
# The example attempts to read the JSON string from a text file, but this could easily be modified to read data from a web server.
# Read the JSON string
jsonString = system.file.readFileAsString("C:\tmp\\json.txt")
# Decode the JSON string and store the results into a variable
obj = system.util.jsonDecode(jsonString)
# Do something with the results. The code below prints the datatype of the results to the console.
print type(obj)
