Version: 8.3
system.util.queryAuditLog
Queries an audit profile for audit history. Returns the results as a dataset.
A description of the returned dataset can be found on the Ignition Database Table Reference page.
Syntax - Gateway Scope​
system.util.queryAuditLog(auditProfileName, [startDate], [endDate], [actorFilter], [actionFilter], [targetFilter], [valueFilter], [systemFilter], [contextFilter])
StringauditProfileNameThe name of the audit profile to pull the history from.
DatestartDateThe earliest audit event to return. If omitted, the current time - 8 hours will be used. [optional]
DateendDateThe latest audit event to return. If omitted, the current time will be used. [optional]
StringactorFilterA filter string used to restrict the results by actor. [optional]
StringactionFilterA filter string used to restrict the results by action. [optional]
StringtargetFilterA filter string used to restrict the results by target. [optional]
StringvalueFilterA filter string used to restrict the results by value. [optional]
StringsystemFilterA filter string used to restrict the results by system. [optional]
IntegercontextFilterA bitmask used to restrict the results by context. 0x01 = Gateway, 0x02 = Designer, 0x04 = Client. [optional]
Dataset - A dataset with the audit events from the specified profile that match the filter arguments.
Gateway
Syntax - Perspective Session and Vision Client Scope​
system.util.queryAuditLog([auditProfileName], [startDate], [endDate], [actorFilter], [actionFilter], [targetFilter], [valueFilter], [systemFilter], [contextFilter])
StringauditProfileNameThe name of the audit profile to pull the history from. [optional]
Note: The project must have an Audit Profile configured in Project Properties. Otherwise this parameter is mandatory.
Perspective Session, Vision Client
Example #1
# This script queries an audit log, checks to see if a user john made any tag writes in the last 8 hours
# (since the startDate parameter is omitted), and writes the results to a table.
data = system.util.queryAuditLog(auditProfileName='AuditLog', actorFilter='john', actionFilter='tag write')
event.source.parent.getComponent("Table").data = data
