Version: 8.3
system.util.modifyTranslation
This function allows you to add or modify a global translation.
Permission Type: Translation Management
system.util.modifyTranslation(term, translation, [locale])
StringtermThe key term to translate.
StringtranslationThe translated value to store.
StringlocaleIf specified, the locale identifying the language of the translation, such as "es" or "es-ES". Accepts both the BCP-47 language tag (recommended) and the legacy underscore formats. Make sure to use locale codes for either format, and not language names, such as "Spanish". Otherwise, the currently set language is used. [optional]
Nothing
Example #1
# This code adds or updates a translation into French
# for the world Hello. Note the u in front "AllΓ΄!", which
# is needed for Python strings outside of the 7-bit ASCII
# range.
system.util.modifyTranslation("Hello", u"AllΓ΄!", "fr")
