system.db.setDatasourceEnabled
Enables/disables a given database connection.
Permission Type: Datasource Management
system.db.setDatasourceEnabled(name, enabled)
StringnameThe name of the database connection in Ignition.
BooleanenabledEnables/disables a given database connection.
Nothing
All
Example #1
# Example 1: Enable a connection
system.db.setDatasourceEnabled("MySQL", 1)
Example #2
# Example 2: Disable a connection
system.db.setDatasourceEnabled("MySQL", 0)
