system.db.runNamedQuery
New in 7.9.4
Runs a named query and returns the results. Note that the number of parameters in the function is determined by scope. Both versions of the function are listed below.
Syntax (Client Scope)​
system.db.runNamedQuery(path, parameters)
StringpathThe path to the named query to run. Note that this is the full path to the query, including any folders.
PyDictionaryparametersA Python dictionary of parameters for the named query to use.
Object - The results of the query. The exact object returned depends on the Query Type property of the Named Query: typically either a dataset when set to Query, an integer representing the number of rows affected when set to Update Query, or an object matching the datatype of the value returned by a Scalar Query.
Client, Designer
Syntax (Gateway Scope)​
system.db.runNamedQuery(project, path, parameters)
StringprojectThe project name the query exists in.
Gateway
Example #1 - Without Parameters
# This example will run a Named Query without any parameters in the Project scope.
# The second argument in the function is NOT optional, so named queries that do not require a parameter must still pass an empty dictionary as an argument.
# Request the Named Query with an empty dictionary as the second parameter.
system.db.runNamedQuery("folderName/myNamedQuery", {})
Example #2 - Gateway Scope
# This example will run a Named Query without any parameters in the Gateway scope.
# The last argument in the function is NOT optional, so named queries that do not require a parameter must still pass an empty dictionary as an argument.
# Request the Named Query to execute.
system.db.runNamedQuery("ProjectName", "folderName/myNamedQuery", {})
Example #3 - With Parameters
# This example will run a Named Query while passing some parameters in the Project scope.
# The Named Query is assumed to have two parameters already defined on the Named Query:
# param1 : A string
# param2 : An integer
# Create a python dictionary of parameters to pass
parameters = {"param1":"my string", "param2":10}
# Run the Named Query
system.db.runNamedQuery("myUpdateQuery", parameters)
