system.db.clearAllNamedQueryCaches
New in 7.9.6
This clears the caches of all Named Queries in a project. If called from the Shared Scope (i.e., Tag Event Scripts, Alarm Pipelines, etc.) then the name of the project must be passed as a parameter.
Syntax - Project Scope​
system.db. clearAllNamedQueryCaches()
None
No Return Value
All
Syntax - Shared Scope​
StringprojectThe Project that contains the named query whose cache needs to be cleared.
No Return Value
All
Example #1
# Calling this simply clears all Named Query Caches.
# This is assumed to run in the Shared Scope, so the name of the project must be included.
system.db.clearAllNamedQueryCaches("myProjectName")
Example #2
# If multiple Named Queries with varying parameters are called in a single script, then clearAllNamedQueryCaches can be used to free up the memory used by all of the newly created caches.
# This example is assumed to run in the Project Scope, so the project parameter may be omitted.
# This creates one cache.
params = {"param1":"A"}
system.db.runNamedQuery("myUpdateQuery", params)
# This creates a separate cache.
params = {"param1":"B"}
system.db.runNamedQuery("anotherUpdateQuery", params)
# Clear all of the caches from the current project. Note that all caches are cleared, including those generated from elsewhere on the Gateway.
system.db.clearAllNamedQueryCaches()
