system.db.removeDatasource
Removes a database connection from Ignition.
Permission Type: Datasource Management
system.db.removeDatasource(name)
StringnameThe name of the database connection in Ignition.
Nothing
All
Example #1
# This will result in the connection named MySQL being removed
system.db.removeDatasource("MySQL")
