system.db.setDatasourceMaxConnections
Sets the Max Active and Max Idle parameters of a given database connection.
Permission Type: Datasource Management
system.db.setDatasourceMaxConnections(name, maxConnections)
StringnameThe name of the database connection in Ignition.
IntegermaxConnectionsSets the Max Active and Max Idle parameters of a given database connection.
Nothing
All
Example #1
# Example 1: Enable a connection
system.db.setDatasourceMaxConnections("MySQL", 20)
