system.db.getConnectionInfo
Returns a dataset of information about a single database connection, as specified by the name argument.
system.db.getConnectionInfo(name)
StringnameThe name of the database connection to find information about.
Dataset - A dataset containing information about the named database connection, or an empty dataset if the connection wasn't found.
All
Example #1
# This example checks the database connection type and selects a query format that matches.
connectionInfo = system.db.getConnectionInfo()
dbType = connectionInfo.getValueAt(0, "DBType")
if dbType == "MYSQL":
# mysql format for a column with a space in the name
query = "SELECT `amps value` FROM pumps"
else:
# mssql format for a column with a space in the name
query = "SELECT [amps value] FROM pumps"
