system.db.runScalarQuery
Runs a query against a database connection just like the runQuery function, but only returns the value from the first row and column. If no results are returned from the query, the special value None is returned.
Permission Type: Legacy Database Access
system.db.runScalarQuery(query, database, tx)
StringqueryA SQL query that should be designed to return one row and one column.
StringdatabaseThe name of the database connection to execute against.
StringtxA transaction identifier. If omitted, the query will be executed in its own transaction.
Object - The value from the first row and first column of the results. - Returns None if no rows were returned.
Gateway
StringdatabaseThe name of the database connection to execute against. If omitted or "", the project's default database connection will be used.
Vision Client
Example #1
# This code would count the number of active alarms, and acknowledge them all if there is at least one.
numAlarms = system.db.runScalarQuery("SELECT COUNT(*) FROM alarmstatus " + "WHERE unacknowledged = 1")
if numAlarms > 0:
# There are alarms - acknowledge all of them
system.db.runUpdateQuery("UPDATE alarmstatus SET unacknowledged = 0")
Example #2
# This code would read a single value from a table and show it to the user an a popup box.
level = system.db.runScalarQuery("SELECT Level FROM LakeInfo WHERE LakeId='Tahoe'")
system.gui.messageBox("The lake level is: %d feet" % level)
lakeLevel = system.db.runScalarQuery(query)
system.gui.messageBox("The lake level is: %d feet" % lakeLevel)
