system.db.commitTransaction
Performs a commit for the given transaction. This will make all statements executed against the transaction since its beginning or since the last commit or rollback take effect in the database. Until you commit a transaction, any changes that the transaction makes will not be visible to other connections. Note that if you are done with the transaction, you must close it after you commit it.
Permission Type: Legacy Database Access
system.db.commitTransaction(tx)
StringtxThe transaction ID.
Nothing
All
There are no code examples available for this function.
