system.db.addDatasource
Adds a new database connection in Ignition.
Permission Type: Datasource Management
system.db.addDatasource(jdbcDriver, name, description, connectUrl, username, password, props, validationQuery, maxConnections)
StringjdbcDriverThe name of the JDBC driver in Ignition. Required.
StringnameThe datasource name. Required.
StringdescriptionDescription of the datasource
StringconnectUrlDefault is the connect URL for JDBC driver.
StringusernameUsername to login to the datasource with.
StringpasswordPassword for the login.
StringpropsThe extra connection parameters.
StringvalidationQueryDefault is the validation query for the JDBC driver.
IntegermaxConnectionsDefault is 8.
Nothing
All
Example #1
# The following code would add a MySQL connection to the Gateway.
system.db.addDatasource(jdbcDriver="MySQL ConnectorJ", name="MySQL",
connectURL="jdbc:mysql://localhost:3306/test", username="root",
password="password", props="zeroDateTimeBehavior=convertToNull;")
