Version: 8.1
system.db.addDatasource
Adds a new database connection in Ignition.
Permission Type: Datasource Management
system.db.addDatasource(jdbcDriver, name, description, [connectUrl], [username], [password], [props], [validationQuery], [maxConnections])
StringjdbcDriverThe name of the JDBC driver configuration to use. Available options are based off the JDBC driver configurations on the the Gateway.
StringnameThe datasource name.
StringdescriptionDescription of the datasource. [optional]
StringconnectUrlDefault is the connect URL for JDBC driver. [optional]
StringusernameUsername to login to the datasource with. [optional]
StringpasswordPassword for the login. [optional]
StringpropsThe extra connection parameters. [optional]
StringvalidationQueryDefault is the validation query for the JDBC driver. [optional]
IntegermaxConnectionsDefault is 8. [optional]
Nothing
Code Snippet - Adding a MySQL Database to a Gateway
system.db.addDatasource(jdbcDriver="myJDBCDriver", name="NewDatabase",
connectURL="jdbc:mysql://localhost:3306/test", username="root",
password="password", props="zeroDateTimeBehavior=convertToNull;")
